Select Help > Sample Data Library and open Companies.jmp.
Select Analyze > Distribution to open the Distribution launch window.
Select Profits ($M) in the Select Columns box and click the Y, Columns button.
The variable Profits ($M) appears in the Y, Columns role. See Assign Profits ($M) for the completed window.
Assign Profits ($M)
Distribution Report Window on Windows
On Windows, click the JMP Home Window button in the lower right corner to view the Home Window. On Macintosh, select Window > JMP Home.
Help created on 9/19/2017
