Start this stored process executing in the background. This message is paired with End Run, which should also be called at some point after Begin Run to wait for the stored process to complete.
-1 = execution failed.
1 = not started.
2 = running.
3 = canceled.
10 = completed successfully.
11 = completed with errors.
Optional, quoted string that specifies that after stored process execution completes, script should be evaluated. If the script is a function taking at least one argument, the function is evaluated with the scriptable stored process object passed as the first (and only) argument. AutoResume and AutoResumeScript are mutually exclusive.
1 if deletion is successful, 0 otherwise (error message to JMP log).
Optional, Boolean. If True, the user is not prompted for confirmation before the attempt is made to delete results.
Waits a specified amount of time (or forever) for a stored process started with Begin Run to complete. If the stored process is complete, retrieves the results, and opens them.
1 = not started.
2 = running.
3 = canceled.
Optional, Boolean. If True, results are automatically opened if the stored process completes in the time specified by MaxWait. If False, results are not automatically opened, and can be manually opened via the object returned by the Get Results message. Default is True.
Optional, an integer. Specifies the maximum amount of time in milliseconds to wait for the stored process to complete. If MaxWait is not specified, End Run waits forever for the stored process to complete.
Optional, Boolean. If True, error messages are sent to the JMP log rather than message boxes. The default value is False.
Optional, Boolean. If True, get only visible parameters. If False, get only non-visible parameters. If not specified, get both visible and non-visible parameters.
Optional, Boolean. If True, get only modifiable parameters. If False, get only non-modifiable parameters. If not specified, get both modifiable and non-modifiable parameters.
Optional, Boolean. If True, get only required parameters. If False, get only non-required parameters. If not specified, get both required and non-required parameters.
Optional, Boolean. If True, get only expert parameters. If False, get only non-expert parameters. If not specified, get both expert and non-expert parameters.
1 = not started.
2 = running.
3 = canceled.
1 = not started.
2 = running.
3 = canceled.
Optional, Boolean. If True, results are automatically opened when the stored process completes. If False, results are not auto-opened, and can be manually opened via the object returned by the GetResults message. The default value is True.
Optional, quoted string that contains the authentication domain of the credentials (username, password) given.
Optional, quoted string that contains an ODS destination (HTML, PDF, tagsets.SASReport12) for any ODS-generated results from the stored process. This requires the stored process SAS code to call %STPBEGIN. The default value is HTML.
Optional, quoted string that contains the SAS graphics device to use when generating graphics in ODS results. This requires the stored process SAS code to call %STPBEGIN. The default value is GIF.
Optional, quoted string that contains an ODS style to apply to the results. This requires the stored process SAS code to call %STPBEGIN. There is no default value.
Optional, quoted string that contains the full path to a CSS file on the client machine that is to be applied to generated ODS results. This requires the stored process SAS code to call %STPBEGIN. There is no default value.
1 if successful, 0 otherwise (value can violate the parameter’s constraints).
