Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
JSL Messages
Display Boxes
• String Col Boxes
String Col Boxes
string col box<<Add Element(item)
Adds the item to the String Col Box. Item can be a single quoted string, a list of quoted strings, or a matrix of quoted strings.
string col box<<Get
string col box<<Get(i)
Gets the values in a list, or the
i
th value.
string col box<<Get Heading
Returns the column heading text.
string col box<<Set Heading("text")
Changes the column heading
text
string col box<<Set Justify("right"
left
center
Specifies the alignment of the contents in the string col box to right, left, or center.
Help created on 9/19/2017
