Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
• Summarize Data
Summarize Data
The Table Summary Command
This chapter describes how to create a summary data table, which includes summary statistics such as the mean and median, standard deviation, and minimum and maximum values.
Summary Table for Companies.jmp
Contents
Summarize Columns
Launch Window Roles
Create a Summary Table
Add a Statistics Column to an Existing Summary Table
Explanation of Statistics
Example of Creating a Summary Table
Help created on 9/19/2017
