Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
Text Explorer
The Text Explorer Report
• Summary Counts Report
The first table in the Text Explorer report window contains the following summary statistics:
Number of Terms
the number of terms in the Term List.
Number of Cases
the number of documents in the corpus.
Total Tokens
the total number of terms in the corpus.
Tokens per Case
the number of tokens divided by the number of cases.
Number of Non-empty Cases
the number of documents in the corpus that contain at least one term.
Portion Non-empty per Case
the proportion of documents in the corpus that contain at least one term.
Help created on 9/19/2017
