Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Consumer Research
Categorical Response Analysis
Supercategories
• Supercategories Options
The following options are available in the Supercategories red triangle menu in the Column Properties window:
Hide
Hides categories within a supercategory in the Crosstab table and frequency chart.
Tip:
If you want the flexibility to show or hide the individual categories in your reports, then do not use the Hide option. Use the Response Level option in the Categorical red triangle menu.
Net
(Available only for a multiple response column.) Prevents individual respondents from being counted twice when they appear in more than one supercategory.
Add Mean
Includes mean statistics in the report.
Add Std Dev
Includes standard deviation statistics in the report.
Add All
Includes total responses in the report. By default, the Total Responses column is always included.
Note:
Supercategories are supported for all response effects except Repeated Measures and Rater Agreement. When responses do not have a natural score, the Mean and Std Dev options are not supported.
Help created on 9/19/2017
