Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Association Analysis
• The Association Analysis Report
By default, the Association Analysis report contains the following reports:
Frequent Item Sets
Rules
Tip:
To order the contents of a table in a report by any of its columns, right-click in the table and select
Sort by Column
Help created on 9/19/2017
