The Degradation Data Analysis plot shows the data and a graphical representation of the model that is currently specified based on selections of Distribution, Transformation, and Path Definition. The plot shown in Destructive Degradation Plot and Options is for the Adhesive Bond.jmp data table and represents a model that includes an optional X variable.
Note: By default, the markers are not colored. To color them to match the model color scheme, select Rows > Color or Mark by Column. Select the X column. Deselect Continuous Scale. Select JMP Default from the Colors menu.
