Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Latent Class Analysis
• The Latent Class Analysis Report
By default, the Latent Class Analysis report contains a Cluster Comparison report and Latent Class Model reports for each specified number of clusters.
Cluster Comparison Report
The Cluster Comparison report gives fit statistics to compare the various models. The fit statistics are BIC and AIC. Smaller values of each indicate better fit. The best fit is indicated in a column called
Best
Help created on 9/19/2017
