Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Naive Bayes
• The Naive Bayes Report
After you click
OK
in the launch window, the Naive Bayes report appears. By default, the Naive Bayes report contains a report for the response column and a Confusion Matrix report.
Help created on 9/19/2017
