The Reliability Forecast report contains the Observed Data report, Life Distribution report, and Forecast report. These tools help you view the current data, compare distributions to find the right fit, and then adjust factors that affect forecasting. Saving the forecast in a data table then lets you import the data into Microsoft Excel for use in financial forecasts. See Example of a Reliability Forecast for an example of the report.
