Denote the standardized data matrix by Xs and define S = Xs’Xs. The singular value decomposition allows you to write S as follows:
If S is not of full rank, then
can be replaced with a generalized inverse,
, where the diagonal elements of Diag(Λ) are replaced by their reciprocals. This defines a generalize inverse of S as follows:
