The Scripting Index on the Help menu provides a brief description and the syntax for JSL functions, objects, and display boxes. Each entry includes an example that you can run and modify to test your own code. And an embedded log window lets you see messages as examples are run.
Click the Search button to begin the search.
Click the Clear button to clear the search text box to begin a new search.
Click the Settings button to set search types and parameters.
Several types of searches are available from the Settings button:
Several search parameters are also available from the Settings button:
Click an item’s Topic Help button to read more about the item in JMP’s online Help system.
