Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Consumer Research
Learn about JMP
Additional Resources for Learning JMP
• Tooltips
Tooltips
JMP provides descriptive tooltips when you place your cursor over items, such as the following:
Menu or toolbar options
Labels in graphs
Text results in the report window (move your cursor in a circle to reveal)
Files or windows in the Home Window
Code in the Script Editor
Tip:
On Windows, you can hide tooltips in the JMP Preferences. Select
File > Preferences > General
and then deselect
Show menu tips
. This option is not available on Macintosh.
Help created on 9/19/2017
