Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
Text Explorer
Topic Analysis
• Topic Terms Report
Topic Terms Report
The Topic Terms report shows the terms that have the largest loadings in each topic after rotation. There are additional reports that show the components of the rotated singular value decomposition.
The report shows a table of terms for each topic. The terms in each table are the ones that have the largest loadings in absolute value for each topic. Each table is sorted in descending order by the absolute value of the loading. These tables can be used to determine conceptual themes that correspond to each topic.
The Topic Terms report also contains the following matrix reports:
Variance Explained by Each Topic
Contains a table of the variance explained by each topic. The table also contains columns for the percent and cumulative percent of the variation explained by each topic.
Term Topic Loadings
Contains a matrix of the loadings across topics for each term. This matrix is equivalent to the transpose of the factor loading matrix in a rotated PCA.
Document Topic Scores
Contains a matrix of document scores for each topic. Documents with higher scores in a topic are more likely to be associated with that topic.
Rotation Matrix
Contains the rotation matrix for the varimax rotation.
Help created on 9/19/2017
