Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Scripting Graphs
Interactive Graphs
• Troubleshoot Interactive Graphs
If your interactive graphs do not work as expected, make sure that you supply initial values for the
Handle()
or
Mousetrap()
coordinates (and other globals as needed). Also make sure that the values make sense for the graph.
Help created on 9/19/2017
