When you reference a column name using As Name(), and Names Default To Here( 1 ) is set, JMP returns a variable reference. That reference is then processed using the standard reference rules.
Names Default To Here( 1 );
Open( "$SAMPLE_DATA/Big Class.jmp" );
As Name( "height" )[3];
As Name( "height" )[/*###*/3];
As Column( "height" )[3];
dt:( As Name( "height" ) )[3];
