Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Formula Editor
• Use Formula Editor Options
There are several options available to you as you create formulas. The following sections discuss each of these options.
Help created on 9/19/2017
