If you prefer not to drag and drop and build the table interactively, you can create a simple table using the Dialog interface. After selecting Analyze > Tabulate, select Dialog from the menu, as shown in Using the Dialog. You can make changes to the table by selecting Show Control Panel from the red triangle menu, and then drag and drop new items into the table.
