Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Profilers
Excel Profiler
• Use the Excel Profiler from JMP
After you have defined model input and outputs in an Excel file, you can profile the model from within JMP.
Select
Graph
Excel
Profiler
Locate the Excel file containing the model and then click
Open
If the Excel file contains multiple models, you are prompted to select the model that you want to profile.
Note that the Excel Profiler is also scriptable, as follows:
Excel Profiler( "path to workbook", <"model name"> ) ;
If more than one model exists, and no model is specified, a window with the list of available models appears. For more information about scripting the Excel Profiler, see
Working with Microsoft Excel
in the
Scripting Guide
Help created on 9/19/2017
