JMP can automatically save scripts to reproduce any data table or analysis in its current state. You can pause any time in your analysis to save a script to a script window (or script editor), in a data table, or in an analysis report. You can then modify the script as needed for future projects. When you are finished with your work, you can then save a script to reproduce your final results.
