Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Discovering JMP
Work with Your Data
• Work with Data Tables
This section contains the following information:
Edit Data
Select, Deselect, and Find Values
View or Change Column Information
Calculate Values with Formulas
Filter Data
Tip:
Consider setting the Autosave Time Out value in the General preferences to automatically save open data tables at the specified number of minutes. This autosave value also applies to journals, scripts, projects, and reports.
Help created on 9/19/2017
