Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Reliability Block Diagram
The Reliability Block Diagram Window
• Workspace Options
Workspace Options
The Workspace panel supports several right-click commands for adjusting the view of the panel. Here are some of the available commands:
Zoom In
Enables you to zoom in to the system diagram.
Zoom Out
Enables you to zoom out from the system diagram.
Zoom Scale
Opens the Set Zoom Scale window enabling you to zoom in or out using a scaling factor. The scaling factor ranges from 0.75 (75%) to 5.0 (500%).
Preview
Enables you to hide or show the Preview window in the Workspace panel.
Align Selected Vertices Vertically
Enables you to align shapes on a vertical line.
Align Selected Vertices Horizontally
Enables you to align shapes on a horizontal line.
Create Series Diagram
Enables you to create a series diagram using the nodes in the diagram. The order of the series is determined by the order of node creation. This option is available only when the diagram does not contain any arrows.
Create Parallel Diagram
Enables you to create a parallel diagram using the nodes in the diagram. This option is available only when the diagram does not contain any arrows.
Help created on 9/19/2017
