The following example uses the Coating.jmp data table. The quality characteristic of interest is the Weight column. A subgroup sample of four is chosen. An X-chart and an R-chart for the process are shown in Variables Charts for Coating Data.
Select Help > Sample Data Library and open Quality Control/Coating.jmp.
Select Analyze > Quality and Process > Control Chart > XBar.
Select Weight and click Process.
Select Sample and click Sample Label.
Note: If an S chart is chosen with the X-chart, then the limits for the X-chart are based on the standard deviation. Otherwise, the limits for the X-chart are based on the range.
Box Plots for Coating Data
The box plots in Box Plots for Coating Data show that the sixth sample has a small range of high values.
Help created on 9/19/2017
