Note: When you generate a np-chart and select Capability, JMP launches the Binomial Fit in Distribution and gives a Binomial-specific capability analysis.
The following example uses the Washers.jmp data table.
Select Help > Sample Data Library and open Quality Control/Washers.jmp.
Select Analyze > Quality and Process > Control Chart > NP.
Select # defective and click Process.
Change the Constant Size to 400.
np-chart displays an np-chart for the number of defects. Points 4 and 9 are above the upper control limit.
np-chart
Help created on 9/19/2017
