JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis •
Oneway Analysis
• Analysis of Means Methods
Analysis of means (ANOM) methods compare means and variances and other measures of location and scale across several groups. You might want to use these methods under these circumstances:
to test whether any of the group means are statistically different from the overall (sample) mean
to test whether any of the group standard deviations are statistically different from the root mean square error (RMSE)
to test whether any of the group ranges are statistically different from the overall mean of the ranges
Note:
Within the Contingency platform, you can use the
Analysis of Means for Proportions
when the response has two categories. For details, see the
Contingency Analysis topic
For a description of ANOM methods and to see how JMP implements ANOM, see the book by Nelson et al. (
2005
Help created on 10/11/2018
