Now that you have your design table, you can conduct your experiment and record your data in the Response column of the design table (Figure 19.6). Your experimental results are in the Software Data.jmp sample data table.
Select Help > Sample Data Library and open Design Experiment/Software Data.jmp.
Figure 19.7 Analysis of Software Experimental Data
Two failures were associated with Web Browser set to Firefox, Operating System set to Macintosh, and RAM set to 8 MB. Notice that this combination led to failure regardless of the setting of Connection Speed.
Figure 19.8 Selection of an Interaction in the Analysis Report
Figure 19.9 Corresponding Selection of Rows and Columns in the Data Table
Three failures were associated with combinations of Web Browser, RAM, and Connection Speed. Note that two of these failures, Firefox, 8 MB, 1-5 Mbps and Firefox, 8 MB, >5 Mbps, are among the two failures for the Web Browser, Operating System, and RAM interaction. Selecting any of these rows in the report selects the corresponding rows and columns in the data table.
Help created on 10/11/2018
