Figure 15.4 shows an application under development in Application Builder.
Figure 15.4 The Application Builder Window
Tip: To hide the grid and turn off snap-to-grid for all applications that you create, select File > Preferences > Platforms > JMP App and deselect these options. You can also deselect these features in the Application Builder red triangle menu.
Help created on 10/11/2018
