JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
JSL Syntax Reference •
JSL Messages
Platforms
• Bubble Plot
Bubble Plot
bp<<Set Shape("Circle"|"Triangle"|"Square"|"Diamond"|"Arrow"|"Custom")
Description
Sets the shape for the bubble. When specifying a custom shape, use the
Set Custom Path
message to specify the path for the bubbles.
See Also
bp<<Set Custom Path(pathMatrix | pathText)
Create Shapes for a Bubble Plot
in the
Scripting Guide
for an example.
Sets a path for custom bubbles.
Arguments
pathMatrix
An
N
x3 matrix.
pathText
A string that contains SVG code.
See Also
in the
Scripting Guide
for an example.
Help created on 10/11/2018
