JMP gives you the flexibility to specify which users see your customized toolbars and buttons. Your changes are saved in a text file with the .jmpcust extension called a customization set. By default, your customizations are shown only to the current user; other users who log on to the computer and open JMP do not see your personal toolbars and menus.
When you modify the Current user customization set, JMP creates a backup file of the set. The file is located in your Windows Users folder within the JMP, JMPPro, or JMPSW folder.
When you modify the All users customization set, JMP creates a backup file of the set. The file is located in the Windows All Users folder within the JMP, JMPPro, or JMPSW folder.
The All Users folder does not appear when you try to browse for it, so you must type the path into the Windows Explorer address field.
Select View > Customize > Menus and Toolbars.
Click Change.
Only you see the changes. The customization file is called usercust.jmpcust. Modifying this file manually might cause unexpected results.
Those who use the selected JMP Add-in, and select JMP Add-In customizations as the Starting Set, see the changes. When you modify the customization set for a disabled add-in, those changes do not appear until you enable the add-in.
Changes appear when the selected .jmpcust file is chosen as the customization set. You create this file in a text editor.
Help created on 10/11/2018
