JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
JMP Reports
Change the Appearance of Graphs
• Change the Pattern and Format of Selected Objects
Patterns appear on some objects such as bars and maps when you select them. You can change the pattern for a specific object in the legend.
Right-click the item in the legend and select
Fill Pattern
to select a new pattern.
To remove the pattern, right-click the item again and select
Revert
Modify the Format of Selected Objects in All Graphs
Select
File > Preferences > Graphs
(Windows) or
JMP > Preferences > Graphs
(Macintosh) to change the Filled Areas preferences.
To change the highlight on selected objects, select one of the following Filled Selection Mode preferences:
Selected Patterned
Striped pattern (the default setting)
Selected Darkened
Solid darker color
Selected Outlined
Outline
Selected Same Color
The Fill Selection Color in the preferences formats the selected object.
To change the color of selected rows in graphic objects when the Fill Selection Mode is “Selected Same Color”, click the Fill Selection Color bar. The default color is red.
Help created on 10/11/2018
