JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Multivariate Methods •
Normal Mixtures
Normal Mixtures NCluster=<k> Report
• Cluster Comparison Report
The Cluster Comparison report gives fit statistics to compare the various models. The fit statistics are BIC and AICc. Smaller values of each indicate better fit. The best fit is indicated in a column called Best.
Help created on 10/11/2018
