Your operating system provides an interface for JMP to communicate with databases using ODBC data sources. Create and configure data sources with operating system software. For example, on Windows 7, use Control Panel > System and Security > Administrative Tools > Data Sources (ODBC); on the Macintosh, use Applications > Utilities > ODBC Manager.
Select File > Database > Open Table. The Connections box lists data sources that you have connected to in the current JMP session.
Click New Connection.
(Windows) In the Select Data Source window (Figure 2.44), click the Machine Data Source tab, select the data source, click OK, enter the user name and password, and then click OK.
Figure 2.44 Select a Data Source (Windows)
Help created on 10/11/2018
