JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Profilers •
Contour Profiler
• Contour Profiler Platform Options
Grid Density
Sets the density of the mesh plots in the surface plots.
Graph Updating
Contains options to change the frequency of updates for the graph. (The difference might not be noticeable on a fast machine.) The following two options are available:
Per Mouse Move
Updates the graph continuously as you drag the mouse. This is the default setting.
Per Mouse Up
Updates the graph each time the mouse is released.
Surface Plot
Shows or hides the mesh plots.
Contour Label
Shows or hides a label for the contour lines. The label colors match the contour colors.
Contour Grid
Draws contours on the Contour Profiler plot at intervals that you specify.
Remove Contour Grid
Enables you to remove a contour grid once one is drawn.
Factor Settings
Provides a submenu of commands that enables you to save and transfer the Contour Profiler’s settings to other parts of JMP. See
Factor Settings
in Profiler
Simulator
Launches the Simulator. See the
Simulator topic
Up Dots
Shows or hides dotted lines that correspond to each contour. The dotted lines show the direction of increasing response values.
Set Contours to Current
Resets the contour lines to be where the current Y values are located. This means that all contour lines cross where the crosshairs are on the contour plot and the controls agree in the Y sliders.
Arrange X Controls Left
Rearranges the X and Y controls horizontally with the X controls on the left or vertical with the X controls at the top.
Hide X Controls
Shows or hides the X controls (Factor Settings and Controls).
Hide Y Controls
Shows or hides the Y controls (Response Settings and Controls).
Help created on 10/11/2018
