JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Predictive and Specialized Modeling •
Partition Models
The Partition Report
• Control Buttons
Control Buttons
Use the control buttons to interact with the decision tree.
Split
Creates a partition of the data using the optimal split. To specify multiple splits, hold the Shift key as you click
Split
Prune
Removes the worst split.
Go
(Available when you are using validation.) Automatically adds splits to the decision tree until the validation statistic is optimized. See
Validation
. Without validation, you simply decide the number of splits to use in the partition model.
Color Points
For categorical responses, colors observations according to response level. These colors are added to the data table.
Help created on 10/11/2018
