JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Scripting Guide •
Display Trees
• Convert Deprecated Dialog to New Window
Because
New Window()
provides more display options and better control over the content and functions of the window, rewrite your
Dialog()
scripts.
Note:
Dialog()
scripts will not run in the future.
The following sections illustrate how to rewrite
Dialog()
scripts as
New Window()
scripts.
New Window Example
Example of Deprecated Dialog
Differences Between New Window and the Deprecated Dialog
Optional Scripts in New Window
Help created on 10/11/2018
