The Stock Prices.jmp sample data table contains data for the dates and values of a stock over time. The variable YearWeek is a computed column representing the year and week in a single variable. Use a range chart to show the high, low, and average close values for each stock. For those weeks where data exists for multiple days, the average of the values is plotted.
Select Graph > Legacy > Chart.
Select Max from the menu of statistics.
6.
7.
Select Min from the menu of statistics.
8.
9.
Select Mean from the menu of statistics.
10.
Click OK.
11.
Select Range Chart from the red triangle menu for Chart.
12.
In the legend, right-click Mean(Close) and select Connect Points.
Figure 13.19 Example of a Combined Range and Line Chart
