JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Multivariate Methods •
Discriminant Analysis
Technical Details for the Discriminant Analysis Platform
• Description of the Wide Linear Algorithm
Wide Linear discriminant analysis is performed as follows:
The data are standardized by subtracting group means and dividing by pooled standard deviations.
The singular value decomposition is used to obtain a principal component transformation matrix from the set of singular vectors.
The number of components retained represents a minimum of 0.9999 of the sum of the squared singular values.
A linear discriminant analysis is performed on the transformed data, where the data are not shifted by group means. This is a fast calculation because the pooled-within covariance matrix is diagonal.
Help created on 10/11/2018
