Use the Maximum iterations option to specify a maximum number of iterations to be used in optimizing the design.
Unsatisfiable Constraints
Select DOE > Special Purpose > Covering Array.
Next to Add N Factors, type 3.
From the Add Factor menu, select 3 Level.
Click Continue.
Select Use Disallowed Combinations Filter.
6.
From the Add Filter Factors list, select all three factors and click Add.
Figure 19.20 Completed Restrict Factor Level Combinations Panel
10.
Click Make Design.
Figure 19.21 Design and Metrics Outlines
Help created on 10/11/2018
