JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Design of Experiments Guide •
Nonlinear Designs
Nonlinear Design Window
• Design Generation
Design Generation
JMP provides a suggested number of runs, determined as follows:
If you are not augmenting a data table, the number of runs is four times the number of parameters plus two.
If you are augmenting a data table, the number of runs is the number of runs in the data table plus two times the number of parameters.
Note:
If you are augmenting a design, the number of runs that JMP suggests or that you specify includes those runs corresponding to observations in your data table. Adjust the number of runs appropriately.
Design
When you click Make Design, JMP constructs the design and adds a Design outline to the Nonlinear Design window. In the Design outline, you can review the factor level settings.
Make Table or Augment Table
The Make Table button creates a new design table. If your original table included existing runs, the new table also includes the existing runs. The
Augment Table
button adds the new runs to your existing table.
Help created on 10/11/2018
