Value of the saved formula SqDist[<level>] for the classification of the observation given in the data table. For details, see Score Options.
Note: Due to an offset term in the formula, SqDist(Actual) can be negative.
Figure 4.11 shows the Discriminant Scores report for the Iris.jmp sample data table using the Linear discriminant method. The option Score Options > Show Interesting Rows Only option is selected, showing only misclassified rows or rows with predicted probabilities between 0.05 and 0.95.
Figure 4.11 Show Interesting Rows Only
Help created on 10/11/2018
