JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Scripting Guide • Efficient Scripts
Efficient Scripts
Tips for Writing Scripts That Run Faster
This appendix provides ideas for writing scripts that run faster and more efficiently. For example, it is possible to control how much time is allocated to finding an optimal design. You can collapse outlines in a report that are not necessary. Or you can write static matrices, which is faster than developing them dynamically.
Contents
Using Matrices
Scripting Data Tables
Scripting Graphs and Display Boxes
Scripting Numbers, Strings, Arrays, and Lists
Programming Tips
Troubleshooting
Help created on 10/11/2018
