The following example uses the Big Class.jmp sample data table, which contains data on age, sex, height, and weight for 40 students. Examine the relationships between different variables.
Select Help > Sample Data Library and open Big Class.jmp.
Select Graph > Parallel Plot.
Select height and weight and click Y, Response.
Select age and click X, Grouping.
Select sex and click By.
6.
Select the Scale Uniformly check box.
7.
Figure 8.12 Height and Weight by Sex, Grouped by Age
From Figure 8.12, you observe the following:
Help created on 10/11/2018
