This example uses the Dogs.jmp sample data table. This example shows you how to produce both a Matched Pairs Across Groups report and the corresponding MANOVA report using Fit Model.
Select Help > Sample Data Library and open Dogs.jmp.
Select Analyze > Specialized Modeling > Matched Pairs.
Select LogHist0 and LogHist1 and click Y, Paired Response.
Select drug and click X, Grouping.
Select Analyze > Fit Model.
Select LogHist0 and LogHist1 and click Y.
Select drug and click Add.
Select the Manova personality.
Click Run Model.
6.
In the Response Specification report, select Repeated Measures from the Choose Response menu.
7.
Figure 16.5 Examples of Matched Pairs across Groups and Fit Model MANOVA with Repeated Measures
Help created on 10/11/2018
