This example uses the blsPriceData.jmp sample data table, which shows the price of commodities over several years. Because the value of the US dollar changes over time, a column named Price/Price2000 shows the ratio of a commodity’s price at any given time to the price in the year 2000.
Select Help > Sample Data Library and open blsPriceData.jmp.
Select Graph > Bubble Plot.
Select Series and click Y.
Select Price/Price2000 and click X.
Select date and click Time.
6.
The report window appears. (Figure 7.15 uses the JMP default colors.)
Figure 7.15 Static Example of Animated Bubbles
9.
Help created on 10/11/2018
