Select Help > Sample Data Library and open Iris.jmp.
Select Graph > Scatterplot 3D.
Select Sepal length, Sepal width, Petal length, and Petal width and click Y, Columns.
Select Grouped by Column.
7.
Select Species and click OK. A different colored contour is displayed for each of the three species.
Figure 5.10 Changing the Nonparametric Density Contour Transparency and Density
Figure 5.11 Adding a Second Nonparametric Density Contour
Help created on 10/11/2018
