This example uses the Therm.jmp sample data table. The data contains temperature measurements on 20 people. Temperature is measured using two types of thermometers: oral and tympanic (ear). You want to determine whether the two types of thermometers produce equal temperature readings. Note that the differences in temperature between the different people are not important. The matched pairs analysis is testing the differences between the thermometers.
Select Help > Sample Data Library and open Therm.jmp.
Select Analyze > Specialized Modeling > Matched Pairs.
Select Oral and Tympanic and click Y, Paired Response.
Figure 16.2 The Matched Pairs Report Window
Help created on 10/11/2018
