Select Help > Sample Data Library and open Hollywood Movies.jmp.
From any window, select File > New > Dashboard.
Select the 2x1 Dashboard template.
6.
Select Preview Mode from the Dashboard Builder red triangle menu.
Figure 10.2 A Dashboard with Two Reports
7.
Click Close Preview.
8.
In Dashboard Builder, select File > Save, and then save the file as a .jmpapp file.
9.
Return to the Dashboard Builder window, select File > Save As, and then save the file as a .jmpappsource file.
Help created on 10/11/2018
