Select Help > Sample Data Library and open Health Risk Survey.jmp.
Figure 13.2 Cluster Summary Report
7.
8.
Click OK in the JMP Alert that appears.
Figure 13.3 Partial Parameter Estimates Report
Figure 13.3 shows parameter estimates for the first eight variables in the analysis. The new cluster names appear in the report window.
10.
Select Graph > Graph Builder.
11.
Enter In what grade are you as X.
12.
Enter Most Likely Cluster Formula as Y.
14.
Click Done.
Figure 13.4 Mosaic Plot of Cluster Membership versus Grade Level
Help created on 10/11/2018
