This example uses the Attribute Gauge.jmp sample data table. The data gives results from three people (raters) rating fifty parts three times each. Examine the relationship between raters A and B.
Select Help > Sample Data Library and open Attribute Gauge.jmp.
Select Analyze > Fit Y by X.
Select A and click Y, Response.
Select B and click X, Factor.
Figure 6.63 Example of the Agreement Statistic Report
From Figure 6.63, you notice that the agreement statistic of 0.86 is high (close to 1) and the p-value of <.0001 is small. This reinforces the high agreement seen by looking at the diagonal of the contingency table. Agreement between the raters occurs when both raters give a rating of 0 or both give a rating of 1.
Help created on 10/11/2018
